| The fertilizer option isn't showing up because it's not on your memory card (probably). If, for example, you are loading your card in Apex and want soybeans in one tank/tab and fertilizer in the other tanks/tab, then you will have to save both of these "Products" to the data card or else it won't show up in the display when you're specifying a product for the tanks.
As far as your ITC not showing up, you'll probably have to go into the GS2 and re-program the ITC with whatever version you have on your card. It takes a while sometimes; I've had that happen in the past. | |
