| OK, that makes it more clear to me.
Our harness does not have pins 12 and 13 wired and I did not know where these wires must be connect to at the FIQ control module side.
Now I have found out that these wires must be connected to the D1 and D2 pin of the FIQ control module connector but I do not have the correct pins for this connector. I have 2 wires stripped off about 5 mm and pushed it in the back of the holes and tighten it with 2 rubber clamps but I do not know how long it is gonna work. So I have to look for 2 correct pin's. For the time being it wil work.
Many thanks!
Henk | |
