NW Central Iowa (Fort Dodge) | Wondering:
I have a MS750 base station and a SN900 used as a repeater on a separate farm about 5-6 miles away. Does anyone know is the base/repeater smart enough to connect to the strongest signal. I was right underneath the repeater and I was only getting about 50% throughput. I know another system out there if the rover sees the base station first it will lock on the base and will not switch to the repeater even though the repeater is a stronger signal. Or is it purely a problem with the GPS/Radio on my tractor and its not smart enough to switch to the strongest signal. |
