| I am writing a VR fertilizer prescription from Farm Works as a voyager2 and trying to get the Pro600 to read it. In the Pro600 the product rate isn't coming across and all the zones are defaulted to 0 lbs/ac. The map does show all the polygons but no color. When we manually enter the correct lbs/ac in the legend for each blend and then look at the map the zones are colored in. Another problem is that not all the zones are correct. It seems that the "island polygons" are not recognized and set to the same rate as the surrounding polygon. I thought this was corrected for. Has anyone had a similar problem and what is the solution?
