| Should have received cable 67259 and cable 75742. 67259 is a Power Bus cable that will be plugged in between display power cable and the power cable going to the batteries. On cable 67259 you will find two pin weatherpack connectors with a pink wire running into them, they will needed to be plugged together. That will allow the 750 to power up that harness when it is turned on.
Cable 75742 will run from port B on the 750 to the EZ-steer controller. It will also have a two pin DTM connector that will be plugged into one of the connectors on cable 67259. The rest of that mess of connectors on 67259 are if you want to power other displays, cameras etc.
The small harness and external switch you find in the bag with 67259 you will not use in this application. | |
