| My sprayer is a wilmar 6200 it has, it has a johndeere GS2 2600 display, and a johndeere rate controller, it still has a mid-tech flow meter and control valve.
as i am spraying, the Warning message comes up "material pump is dry, shut off immediately." yesterday this happened and i shut off the swath pro and it started working and i turned back on the swath control and it worked the rest of the afternoon. Today it ran fine for a while, then the message came up again and i can't get it to start spraying again. i have tried shutting off the swath control off and on but its still not working. is it a "kink" in the gs2, or is it a problem with the control valve, or even the flow meter? | |
