Override Sensitivity setting is probably too high! Adjust the EZ-Steer system’s Override Sensitivity setting. If you experience manual disengage faults during normal operation, reducing the Override Sensitivity value until the manual disengage occurrences are eliminated. Note: Lowering the Override Sensitivity value too far can make it difficult to disengage the EZ-Steer system when you take manual control of the steering wheel at the end of rows. Be prepared to disengage the system using either the engage/disengage buttons on the display or the optional footswitch. |
