Eastern Iowa | I use a JD Switch #AT157547 $40 and the Switch Bracket #A71505 $30, it is a push button switch designed to go on the row unit parallel arms, have to push the button to stop logging. I mount these on Kinze and Case planters by adding a 2 1/2" long 1 1/2" angle iron bolted to the parallel stops whichh are used to "push" the button in when the planter raises and the row units hangs down. | |
