NE Illinois | I would go with a used 2600 Display and a new Starfire 3000 Receiver. The 2600 will be a cheaper route than the 2630 to get started. You could go with a used iTC receiver to save some money, but IMO, the 3000 is definitely worth the extra money. Either the 2600 or 2630 can also be used as the monitor if you end up with a SeedStar 2 Deere Air Seeder. These displays will give you documentation capabilities, as well. If you have a Deere combine, these displays can double as a yield monitor if the combine has a mass flow and moisture sensor. | |
