| On the power bus cable, make sure to look at the 2-pin weatherpack connectors with pink wires going into them (I believe one is labeled relay). Those should be plugged together as that will power the output side of that harness when the FMX is powered up. Out of the box those connectors will not be plugged together.
If thats already done, check and see if your getting a constant voltage from the 2pin DTM connector that you are plugging your NAV harness into, if that is all good, you might be looking at a NAV problem. | |
