Western Iowa | When hooking up the ez steer to the 750, you plug the t2 box into the wire harness of the 750. Your main 750 harness plugs into the square power in connection on the back of the 750. You dont use port a or b. You need the additional power supply cable to plug into the 2 pin connection on the harness that goes from the t2 to the 750. I used the original power cable from my ez 500. I just unplugged the 2 pin connector from the 500 harness (with the cigarette lighter adapter) and plugged it into the 2 pin harness of the 750. So on your 750 ez steer setup you have 2 power cables. My dealer helped me figure this out. Don't know the part number of the power cable but I'm sure there will be some posts soon that include it.
Edited by iafarmerken 4/19/2011 08:07
