Near Intersection of I-35 & I-90 Southern Mn. | Not sure of all the steps off the top of my head.
Part of the setup involves a question with three choices: 1) liquid 2) tru-counts without inverter 3) tru-counts with inverter.
This would seem easy enough but I found a problem when trying to use choice #2 which seemed appropriate.
An error has crept into the firmware for the EZ-Guide 500 V 5.1. Due to this error, the logic is not reversed as it needs to be for a planter without an inverter. The solution was to downgrade from V 5.1 back to V 5.0.
You probably have other questions that I haven't addressed. |
