Posted 4/15/2011 22:13 (#1726558 - in reply to #1723739) Subject: Re: 8430 on SF2 wandering back and forth of line
8430 MFWD should have a wheel sensor if its autotrac ready. It should have a king pin sensor on the left side. You will see a wire that runs under a metel shield along the axle then goes into the kingpin under where the fender mounts. You will have to remove the front fender to get to it if you have fenders. If its an ILS then it wont have a king pin sensor. It uses a different style of sensor
