mora | i need to plumb a set of couplers for a hydraulic motor. i have a source for pressure and am inserting a needle valve in-line before the coupler to regulate flow if needed. the question i have is where to send the return oil. i already have a fitting on the oil filter housing for return of the oil from the loader. would you just by a tee and put it on the housing with the loader return? or is there a better place to return the oil? the loader will probably not be in use while the hydraulic motor is in operation if that makes any difference. thanks
kevin | |
