Southern Indiana | 1st question is there a place to hook a gauge to the high pressure side? The one right beside the compressor that has a sensor on it that I've found but the sensor feals like it dosent want to come out and I don't want to break it. 2nd question would the lo pressure light come on if the compressor wasn't working? The compressor has the cover over the clutch so you can't see it kick on and off. It dosent sound like it is working either, but we put 3 small cans in the system so I think it has to be working right? After the 3 cans the lo light still is coming on and still no cold air. So now I've run air through the lo side gauge and charged it with air to 95 psi and I am sitting here watching the gauge and it hasn't moved a bit. I know will have to vacuum the system out and start over when we find the problem. But I don't know what the problem is. Any help and we do have power to the compressor. | |
