Nebraska | Good to hear you are hainge success with the equipment. I am using prescriptions that are written in actual lbs of N. I needed to use the NH3 scale factor to make them come out right. There is something funny going on with the meter number though. If you put in the pul/gal and hit the liter/gal button it will give you a metric converted cal number that is close to the Raven tag number. This leads me to believe something is messed up with the internal math of the firmware. | |
