roaming | your lines are saved on your card, so if you've never cleaned off your card, then your lines are there. You can verify they are there by powering up your display with the card installed, and go to Data Management > Map. Select a Field that has some swaths in it, and select Swath as the data type to view. You'll then see all swaths that are in that field. (if you don't see anything, make sure swaths are turned on on your map options) | |
