| Hello
I finally decided to register
This is a issue :
"For the camera pinout for all 4 Ports on the FmX, you will need:
Pin 8 for Ground
Pin 7 for Video Input
Pin 9 for Power Out 12+
Note: Pin 6 is labeled for video Ground. Don't use this pin for ground, use Pin 8. Pin 6 will cause poor resolution from the camera.
Edited by swkansasfarmer 5/3/2010 19:12"
in this topic I find relay nice explanation how to pinout 12 pin Trimble doutch connector for video connection. good but if I must put together ground and video ground from camera i must be sure about pin out of camera. And this is a problem :
http://www.facebook.com/#!/photo.php?fbid=207559699255519&set=a.207...
Have no idea how to pinout this connection without slaughtering it
Edited by shaulinis 3/19/2011 14:30
