Posted 3/18/2011 10:19 (#1676666 - in reply to #1676637) Subject: Re: Installing a trimble 750 w/ezsteer. Wires?
SEQ, Australia
MDuke - 3/19/2011 00:57
Also as an alternative to turn the EZ-Steer on, if you disconnect the switch and connect R2 and P2 the EZ-Steer will turn on with the screen.
Which is what I meant when I said joining the two pin weatherpack connectors together allows you to turn the system on via the screen.
