Posted 3/15/2011 20:26 (#1672137 - in reply to #1671839) Subject: Re: JD 4710 Sprayer HELP!
NESD
I have run into this several times, what I have had to do then is cut the pin out with a torch, cut away the ends of the pin until the scissor can be removed and then continue cutting the pin away as deep as possible, by then you should be able to drive what is left out.
