Posted 3/13/2011 20:25 (#1668492 - in reply to #1668425) Subject: Re: sprayer nozzles
St.Clair Co. IL.
20" spacing at 50# pressure, what will I need to adapt to the hardi triple tip body, also is it true that with the AI tips you are only getting half the pressure out the tip? I mean 50# pressure=25# out the tip.Just asking ,I can use different pressure I not married to a set pressure, that's just what I use to get the gals. I want at the speed I run.
