southern mn. | Make the tongue adjustable length so when your not using it , it will not obstruct your vision. Length depends on the implement but found out when I pulled the p/u behind our rock picker when I made the 1st turn I took out front turn signal and headlight! When I pull the p/u I put transfer case in neutral and transmission in park and just make sure key is not in lock so steering wheels will turn. Operating manual says nothing about leaving vehicle running when towing | |
