Iowa | Check for spec ft/lbs on the PTO slip clutch and the pickup slip clutch. Also like the others have said, if the latches haven't been sub'd then they have probably stretched and should be replaced and readjusted to spec. I do all of my own spec checks and bring the baler back into spec every year. This year I couldn't get the gate latches into spec and had to replace them with the new cast ones, I also ended up rebuilding the PTO slip clutch because it couldn't be brought back into spec. Last year the Netwrap was out of spec. Here is the yearly spec check I do on my JD 567:
Adjust Bale Size Indicator
Slip Clutch - PTO, Pickup
Adjust Upper Drive Roll Chain
Starter Roll Drive Chain
Upper Drive Roll Sprocket Alignment
Adjust Lower Front Gate Roll Scraper
Check Belt Tracking
Adjusting Belt Tracking with COVEREDGE Net Wrap
Adjust Twine Arm-to-Starter Roll, Cutter Link Support, and Twine Arm Stop
Adjust Twine Arm-to-Cutter Link Support
Adjust Twine Arm-to-Twine Stop
Adjust Twine Cutter-to-Twine Arm
Check and Adjust Twine Cutter Knife
Adjust Twine Cutter Contact Tab
Adjust Clearance Between Cutter Link Support and Twine Arm
Adjust Twine Cutter Tension
Adjust Twine Indicator Retaining Strap
Adjust lower Net Wrap Guide
Check and Adjust Net Wrap V-Belt Idler Tension
Check and Adjust Net Wrap Switch
Adjust Net Wrap Counterknife
Check and Adjust Net Wrap Feed Roll Brake
Edited by mulberrygrovefamfarm 3/12/2011 19:51
