Posted 3/8/2011 15:20 (#1658162 - in reply to #1658121) Subject: RE: water logged pressure tank in well
Orange County NY
Does your tank have a air valve on it? If it doesn`t pull your presure ga. off and screw a tire valve in and blow it out with a compressor.
Make sure you have the well pump off and a water outlet open. Then close it up and start the pump with zero presure in the tank.
