Jamestown North Dakota | check to see if the quick refill valve under the tank is closed. it is under the sprayer tank about the center line.
are you using aim command or conventional? If you are spraying conventional, make sure you go to manual and drive the valve open all the way and than set the pressure. at higher speeds if the valve isnt open all the way it will cause the boom sections to spray as as you stated
Edited by fmmiller1 3/7/2011 06:22
