Near Intersection of I-35 & I-90 Southern Mn. | caseski - 2/28/2011 21:34
The easiest way to do this would be pull into the field and head the direction you want to travel at, push the infomation three or four times, read the filtered heading, and then set your a+ line on that heading and off you go.
I agree, the A+ setting with the intended heading (found by pushing the info) will take you on a straight path on the desired heading on the first pass. With our tillage tractor this is what I do for almost every field. |
