Highland co. Ohio | Mine would flash the startup screen, shut off and do it again continously. This happened the second or third time I turned it on. I read on here holding the 3 buttons on the left while turning it on resets the factory defaults. I did this and it hasn't happened since.
In advanced mode you can stop a field and come back, after you hit the new guidence button click on select a stored field and if your at that field it should show a map of it, if your not there zoom out untill you can select it. Then you can select any of the ab or headland patterns previously used in that field. You can also add a new AB line there, I have one farm with 11 fields I saved with one name and it has all 11 headland patterns and ab lines stored if I need them when I come back.
-Jeff | |
