Posted 2/19/2011 15:35 (#1623302 - in reply to #1623206) Subject: Re: Raven Smartrax Question
NE South Dakota Clark, SD
It should work very good for you. Make sure you calibrate the TM1 on some flat concrete and you should be set. I have been working with Smartrax for 3 years and have yet to see a GPS enhancer. You will V5.2 in your Smartrax box. Your definately the perfect candidate for your own RTK base station. If you are fairly flat with straight lines you should be good.
