Posted 2/18/2011 20:33 (#1622043 - in reply to #1621684) Subject: Re: Trimble section/rate control on sprayer
If your using raven 460 you have an external boom switch box right? I would use a full harness solution. The field iq cab kit is $795, the full harness kit is $1595, raven adapter harnesses roughly $200, and variable rate unlock for fmx $750. This will allow you to control whole system with your fmx and no need for external switch box.
