| Heres my question, I'm wanting to add a boomless spray tip to my sprayer where it can be controled seperate from the other boom sections. I have barpits and ditches with alot of telephone poles. This way i can mount it on the center frame and spray keeping my boom section folded in. The sprayer has a ag leader insight with direct command and autoswath running off the jd rate control. How can i set up another boom valve that is not going to be used when spraying in the field ? (not really another section) Its just going to be used for the barpits and ditches doesnt need to map or record. | |
