Near Intersection of I-35 & I-90 Southern Mn. | The Integra will work very well with your Raven components. An Edge or Insight will also work well.
In all cases, the Ag Leader display will need the Auxiliary Input Module, a Switchbox, a Liquid Product Control module and the wiring to put it all together.
The wiring that is chosen will depend on your individual situation.
If the sprayer is a pull-type that uses a 16 pin connector/disconnect at the hitch then a special Ag Leader cable can be used for this purpose. This cable connects the various Ag Leader components which would be located in the tractor cab and terminates in a 16 Pin connector at the hitch. In this scenario no changes would be made to the sprayer. The sprayer could be hooked to one tractor with the Ag Leader setup or hooked to another tractor with the Raven setup.
If the sprayer is a pull-type that uses the older 6 Pin trailer type plug and separate flow connector, Ag Leader does not make a cable that terminates in those connectors. However we do. This would be equivalent to the above setup but uses different connectors at the hitch. This cable only supports three boom sections at most.
Another approach with a pull-type sprayer would be to remove the Raven harness and use a different Ag Leader harness. With this setup, the Raven product cable would be removed and the Liquid Product module would be mounted on the sprayer. This is a very clean arrangement but would not allow the sprayer to be run with a Raven quite as easily unless the original cable were used again.
If the sprayer is a Self-Propelled then there are various layouts depending on the model of sprayer. In some cases there are adapter cables and in others Ag Leader cables are used with the original components with the original wiring being unattached but left in place.
