Posted 1/26/2011 17:06 (#1574302 - in reply to #1573130) Subject: RE: Trimble intros a new modem
Fargo, ND
The DCM-300 will work with the FMX, CFX-750 and I believe the 262 receiver. What's interesting is that the DCM-300 plugs into the USB port on the FMX and CFX. You can use a USB hub if you need to keep a USB memory stick plugged into the FMX or CFX. You need to use AgRemote to set up the modem when using the 262.
