•Other than CaseIH's Pro 600 what other monitors will work with CAN sensors on a planter? nt
GIred
Posted 1/25/2011 07:11 (#1571199 - in reply to #1569865)
Subject: Re: •Other than CaseIH's Pro 600 what other monitors will work with CAN sensors on a planter? nt
Grand Island, NE
The only other monitor that will work with the "smart sensors" is a Dickey-john Seed Mgr. (Not the Seed Mgr. SE) Dickey-john no longer makes this monitor but there are a few used ones around I'm sure. Another option is a Dickey-john ISO compatible PDC module. These will work on a Pro600 but would require the Early Riser type of sensors. It could also give you VR option as long as it doesn't overload the Pro600. If you have any questions, give me a call. 308-381-2905
Dale
