Classifieds (11)
JD GS1 card setup problem
Precision Talk
mikejd4020
1/26/2011 18:53 (#1574481 - in reply to #1574185)
RE: JD GS1 card setup problem
Bainville, MT
What is the size of the card you are trying to use? must be 32 or 128 kb. If you are you using a larger card it will not work.
Mike
Are you using the windows format or doing it from the C:/ prompt.
You are having a data card problem for sure.
Is it a JD card?
please more information about your card?
tyrider
: 1/24/2011 16:25
mikejd4020
: 1/24/2011 17:47
JakeH.
: 1/24/2011 21:25
Re: JD GS1 card setup problem
Francis
: 1/24/2011 21:53
kvanness
: 1/25/2011 12:14
tyrider
: 1/26/2011 15:23
mikejd4020
: 1/26/2011 18:53
tyrider
: 1/26/2011 22:18
kvanness
: 1/27/2011 10:50
tyrider
: 1/27/2011 13:04
mikejd4020
: 1/30/2011 02:26
