| To run the iGrade like you are talking you would need to tie into the CAN network. I don't know if the 650 runs on can or not. If it does then you'd have to find the controllers and tie in points to get everything to work. I'd be willing to go out on a limb and say it will be pretty time/labor consuming to get it done IF it is even possible. I would think if you priced in your time and all the modifications that would need to be done and then all the parts needed to make it would you would be FAR above what the factory laser option is. | |
