Central Il Morton | EbertFarms - 1/21/2011 13:44 could be filter isn't on tight enough, lost fuel pressure overnight by the bleeder screw being open a little, or stripped (the plastic bleeder screws are a maintenance item unless you go to a stainless screw). get the code and get back to us.
He cranked the engine over with the sensor hooked up but with out the air filter element in place. Don't know why dash light went out then came back but cleared code and all seems to be well.
Thanks all
pointrow |
