Brazilton KS | That type of message generally means there is a valve somewhere (other then the rate control valve) closed....tank valve, hose valve, ball valve by the breakaway(on Raven anyway), excess flow valve on tank.....for some reason the controller is calling for more product and the valve is responding but nothing is coming out. Could also be the limit switch in the rate valve, presuming it is a servo activated valve. | |
