West Tennessee | We ran a 3630 for about 10 years. The Peugeut engine has enough power for most every situtation but needs to be reved up to keep things going. If you have a serious hill you should use 2nd gear and not 3rd. On flat ground we've run a lot in 4th gear. Not really a machine to hand over to the hired help unless they're careful. It won't take lots of abuse without giving you some grief. That said we sprayed a lot of acres and found ours to be very reliable unless handed to a hired hand who was abusive or wouldn't watch the temp gauge. :-( If you have to work on the motor it is expensive but name me one that isn't.
