| Waterbottle is right the manual is a bit confusing. One more thing, don't use the end of the first headland as your B point that may be part of your problem. Make sure the B point is marked before you get close to completing your first headland. One thing you should notice is that as soon as you mark your A point it will tell you to drive at least 160ft and then mark your B point. You will find that after you drive exactly 160ft there will be a B pop up on the menu on the right of the screen. After you have selected B, the "complete headland" option pops up. I hope this is not to confusing. | |
