Near Intersection of I-35 & I-90 Southern Mn. | Follow the link that Lance has suggested.
The adapter cable that you would want is the Dickey John choice. This will be the 4 pole round connector that your planter monitor requires.
The Raven and Hiniker choices are for use with those products as they use a different type of connector.
Once you plug it in you should get a speed indication on the planter monitor. You will need to play around with the speed calibration number in the planter monitor to get the speed to read correctly. Without the proper calibration number, your ground speed, population and acreage will be incorrect. |
