Bow Island, Alberta | I'm looking at buying a used CaseIH 8120 combine with a y & m monitor. If I get the receiver to do mapping, what else would I need to use this equipment for guidance in a JD tractor? Likely would put it into a 8400 or 8410. Might just use it for "painting" while spraying, but may consider autosteer as well.
I currently have 1 tractor set up on JD starfire2 with the 2600 display to use for seeding and most of the spraying.
Thanks for your help. | |
