Butterfield, MN | Figure out what it takes for sending in external NMEA messages, and it should work if they have any provisions for doing that. One nasty thing about the 262 is that if you have one message that needs to be turned on to 10 Hz, all other messages that you need turned on will also be sent out at 10 Hz, even though it's not necessary (or even helpful) to have them turned on that fast. Hopefully the s3 won't get bogged down. | |
