Butterfield, MN | I'm not right in front of one, but sure it can. If you are trying to retrieve a line, and you are using the same field boundary for that field, you can grab it that way. Otherwise, you can grab it if it's a certain distance from your current location, although you'd want to name it something specific, such as E-W North Johnson Field for something like that so you know right where you are lining back up. Keep in mind, if you aren't using at least Omnistar, you'll have to nudge the line over to get yourself lined back up. | |
