Posted 12/21/2010 21:46 (#1499693 - in reply to #1498989) Subject: Re: AFS Pro 600 w/262 reciever to GS3 2630 Display
roaming
you can send GPS directly to the 2630 from the 262, but it won't be terrain-compensated. As Crush says, you'll soon be able to output corrected position data from the CNH NavII. Cable to do this is 380002422. Cable to go directly from the 262 is 87298129. (87298129 will also work to get signal from the Nav, but it's a giant cable that is way overkill for in-cab use where it won't be exposed to the weather.
