Posted 12/18/2010 01:13 (#1492299 - in reply to #1492286) Subject: Re: HP required for 2 btm roll over plow 3pt
ECMN
We used to pull 3 16" bottoms with an IH 656 60 hp. We had some spots with pretty heavy clay or what we called "gumble" sp? I think it would have been in the 3.5 to 5 mph range. So I would say you have plenty of power, rollover or straight bottom should require about equal power. Ok now I see the no weights or fluid part, I would say you may be looking for some ballast, depending on the tractor weight.
