IL | Where would you mount the antenna on a 8920 magnum? I think on the hood over the axle would work better but I am not sure if the cab would block any satellites. How many satellites do you guys usually see when using WAAS? On the 4wd I usually see between 8-12 and that is with the antenna on the cab. Haven't mounted it on the magnum yet. Any input greatly appreciated.
BTW with the ez-steer and ez-guide 500 on the 4wd it was shooting arrows. Very pleased with the system. | |
