Eastern Iowa | Got a customer with a 2009 JD 1790 16/32 planter with Seedstar 2 and a GS2 2600 who would like to put AL Surevac clutches on the Corn rows only. The planter has the row command harness on, AL makes an adapter at the row for hook up to the Surevac. What does this customer need from JD to Make it work, will it work for just the corn rows only? I beleive the planter has the big Row Command plug in the middle, do we need just the JD's module and some cables to tie into the Main Harness? Thanks | |
