Near Intersection of I-35 & I-90 Southern Mn. | ZELGY - 11/5/2010 16:06
The Raven Sidekick Pro can only be controlled through Raven controllers (Envizio Pro, Viper Pro, SCS 5000 and 4X00)!
This is correct because the Pro contains a built-in Raven module which will only communicate with Raven products as mentioned.
If you are interested in Chemical Injection on the 4730 there are other ways to accompish this. We have installed many Raven Sidekick systems (not Pro but the standalone console and pump) on 4730's as well as many other sprayers.
The small Sidekick console controls the pump and the GS2 system would still run the main product (carrier). The two system are tied together in the sense that during normal operation the GS2 would start/stop the pump as it turns the booms ON/OFF. |
