| Well I have not had time to post what I found out on my Trimble system. It was going into float everytime i turned around on the end no matter how close to base or far away. Have lots of sats then none and would get back to fixed almost as soon as I straightened up. Talked to a neighbor and he has been running the trimble rtk since it came out and told me to check my antenna, I informed him i broke the whip last year and replaced it. Said that dont matter the coil of the antenna can get dead spots in it and cause it to act funny. Well all last spring i had this problem as well, just not as bad. So I had a new antenna as I could not just buy the whip at the case dealer. So I switched them out. Man what a difference, can count the times it has lost signal on one hand in the past week and a half. I guess he was right as it is working better then it has ever worked.
Brad | |
