Near Intersection of I-35 & I-90 Southern Mn. | Pat H - 11/1/2010 15:37
I found the implement switch jumper - I assume I just cut the loop and wire in my switch and viola!
Thanks,
Pat
Yes, that is correct. Remember the switch must complete the connection when the implement is in the "down" or working position. There is no menu selection to change this.
With an Application Rate Module with an implement switch it is possible to change the "sense" of the switch. This is not the case with the Application modules such as your Liquid Module.
Also remember that you will need to install a jumper back in the loop when you move the Liquid Module back to your sprayer.
For example with my NH3 bar I really should have an implement switch in the loop but I just have it jumpered. If I had the implement switch it would prevent inadvertent opening of the NH3 ON/OFF valve when the bar is "UP". This isn't really much of a problem but an implement switch is recommended.
Edited by tedbear 11/2/2010 08:11
